Hello colleagues, I am looking for the source code for a CLONE PI AVR that works with the ATmega 8. Thank you..
Hi Detectorist#1, there is actually no true ground balance, I would just port the code to a chip and for example set the ground as in Carl's code and make some other changes to the schematic, such as putting in a bipolar power supply, sort of like a mod version.
Hi, I don't think I have ever seen source code for any of these projects. Only hex is provided.Originally posted by algan View PostHello colleagues, I am looking for the source code for a CLONE PI AVR that works with the ATmega 8. Thank you..
Interesting!
Until a few days ago I could access the link without problems, today I can't.
Maybe it's an internal problem on the server, it doesn't necessarily mean that it's about "sanctions"...
I never made a Clone PI, I never went into the details.
I see there are many versions and revisions.
I checked my archives and found what I am adding here in the attachment.
I don't know how to explain the details.
Maybe it will work, maybe it won't.
But the source code was never released, so I don't have it.Attached Files
I also found some comments related to this version as well as a set of files for the pcb, I attach it in the attachment.
Also there is complete web page saved in the folder, lot of comments and info too. Unpack and open in browser the "web" folder content.
"...ClonePI is slightly processed variatom impulse metal detectors Tracker PI (Koschey PI) Kolokolova-Shchedrin
(from this and other structures referred to the authors can be found at www.metdet.ru).
Difference from Tracker PI following:
The controller of Atmel replaced by the controller from Microchip.
"Backward Integration" replaced the normal 12-bit ADC.
To display information using LCD, LEDs are not supported.
The device has a fast and slow program avtopodstroyku (slow at a target detection).
The Office carried out buttons, "vertelki" no.
Visually level of response displayed "potmeter (sliders), with volume levels 3 ... 7 frequency sound depends on the level of response.
On the screen displays the current supply voltage, while reducing voltage below the specified warning is issued.
In a room ClonePI showed strong detection coins 5 kopecks. USSR at a distance of 25 cm, which is not worse than the commercial version of its prototype.
In doing so, the usual (not korzinochnaya) coil diameter 19 cm, 27 turns, 1 st..."
